It is currently Tue Sep 08, 2026 3:16 pm
PostPosted: Thu May 29, 2014 11:51 am
Hello,
Can someone educate me on the mechanics of the inflatable lumbar seats on my 2014 TI? Thank-you
PostPosted: Thu May 29, 2014 4:24 pm
If it is the inflatable one Hobie Cat sells... It is similar to a camping mat. Unscrew the valve to allow air in. The foam should expand and suck air in. You can add pressure by blowing into the valve, then screwing closed while plugging with your tongue. You can make adjustments for comfort by unscrewing the valve and allowing air out.
PostPosted: Fri May 30, 2014 4:59 am
Thanks for the timely reply.
:wink:
