It is currently Tue Sep 08, 2026 2:50 pm
 Post subject: 2015 AI Sail Question.
PostPosted: Fri Feb 13, 2015 8:26 pm
I have seen quite a varied array of photos of the 2015 Adventure island since late August, with different sail designs.
Is the sail in this photo the actual sail that comes with all new AI's ?
Love the fact that it has full length batons.
Photo supplied by Kayakingbob.
2021 Dune Hobie Lynx
PostPosted: Fri Feb 13, 2015 10:26 pm
I'm guessing the mast is longer that on the pre-2015 A.I. models?
Might be a worthwhile purchase for anyone looking to get a bit more speed from their older A.I.s
Mike.
PostPosted: Sat Feb 14, 2015 3:00 am
Mike.
I was actually talking about the photos of 2015 AI's, not previous models.. The sail in various photos are different.
PostPosted: Sat Feb 14, 2015 5:03 am
Mike.
The AI 2 (=2015 model) mast will not fit other AI models.
PostPosted: Sat Feb 14, 2015 8:31 pm
Mike.
Is the mast a larger diameter?
Mike.
PostPosted: Mon Feb 16, 2015 9:19 am
Yes - that's the new sail for the AI (2015)
Jacques Bernier
http://www.hobie.com/
PostPosted: Tue Feb 17, 2015 6:14 am
mingle wrote:
Mike.
Mike.
Stringy corrected me on this. See http://www.hobiecat.com/forums/viewtopic.php?f=70&t=7276&p=250295#p250295
Here is an image of the AI and AI 2 bases. They are the same diameter and the latching ring is the same. Only the furling ring is different (slightly higher in the AI 2), but not a problem for using the newer AI 2 mast in place of the AI mast. Be aware that the AI mast (pre-AI 2) is capable of driving the AI bow and ama well under water in strong winds. So, the larger AI 2 mast & sail will not serve any purpose in high winds--they need to be furled to varying degrees. They should help in light winds.
PostPosted: Tue Feb 17, 2015 8:05 am
Obviously the deck is higher in the 2015 which required that the furling drum sit a bit higher. Thanks for the photo.
