It is currently Tue Sep 08, 2026 1:44 pm
PostPosted: Sun Aug 05, 2018 4:38 pm
I have a chance to buy a new 2017 Adventure Island for 15% off. Are there any improvements in the 2018 that might make it worth 15% more?
I see that the 2018 has the 180 drive, but I can't see traveling all that much in reverse. Or is it more important than that?
Any other differences?
PostPosted: Sun Aug 05, 2018 5:04 pm
I thought the 17s had 180 drives? My 17 TI does...
PostPosted: Mon Aug 06, 2018 7:13 am
I don't know, but the ads online for the 2018s say "new for 2018! 180 drive".
I found an old post that said the 2018 TI had a new furling line also, but can't find anything for the AI.
PostPosted: Mon Aug 06, 2018 10:41 am
Our 2017 TI came with the 180's - I'm sure it was new for '17.
We find it a useful feature, but not essential - if you just have a paddle to hand you can slow/stop/back-up if needs be, but pulling the MDs into reverse has helped us stop quickly on a couple of occasions when needed (e.g. when coming ashore in coves & spotting a hidden rock under the surface!).
What we often do now is put one in reverse, one forward when manoeuvring carefully in tight spaces against tide/wind, with paddle in hand to control side movements.
But this could also be done with pre-180 drives of course, by turning one around.
PostPosted: Tue Aug 07, 2018 7:36 am
No one knows what's new for 2018!? Come on!
PostPosted: Wed Aug 08, 2018 2:03 pm
I just got a 2018, and had a 2017 at one point (Both AI's - don't ask :)
All that I have noticed is that:
* Mast and Aka clip upgrades come pre-installed - Otherwise you get them from the dealer for free
* The new trampoline are better designed (with a latch to tie them when rolled up and not in use
* The side pockets are rubber, not string net
* The adjustment button for the drive (which lets you select a number to spread them optimally) is a button on top of each pedal as opposed to a lever on its side (which you probably will notice all of the ONE times you will use it :)
I also had the 17 withy the 180 drives, so that would not qualify as a change
I hope this helps. AFAIAC, these differences are trivial to say the least. 15% is worth it (that's how I had bought my 2017, BTW)
