It is currently Tue Sep 08, 2026 12:43 pm
PostPosted: Sun Jan 24, 2021 11:08 am
How does the pre-2015 Tandum island hull compare to the 2015+ Adventure Island hull. Haven't had any luck finding height dimensions to compare. Length isn't a concern.
PostPosted: Tue Jan 26, 2021 7:31 am
On the TI, there is very little different in overall dimensions between the two hulls.
PostPosted: Tue Jan 26, 2021 10:53 am
How does the pre-2015 Tandem island hull compare to the 2015+ Adventure Island hull.
AI vs TI Hull? The TI has more volume / length / width.
Try the Wayback Machine to locate older model specs. This site archives websites, so you can go and see what was on a site back in history.
https://archive.org/web/
https://web.archive.org/web/*/hobiecat.com
2014 Tandek=m Island:
Specifications
Crew: 1-2
Length: 18' 6" / 5.64 m
Width: 30" / .76 m
Beam w/ Amas Out: 10' / 3.05 m
Beam w/ Amas Folded In: 4' / 1.22 m
Capacity: 600 lbs / 272 kg Tooltip
Fitted Hull Weight: 124 lbs / 56.25 kg Tooltip
Fully Rigged Weight: 190 lbs / 86.18 kg Tooltip
Mast Length: 18' / 5.49 m
Sail Area: 90 sq ft / 8.4 sq m
Hull Construction: Rotomolded Polyethylene
Current Adventure Island:
MIRAGE ADVENTURE ISLAND SPECIFICATIONS
CREW: 1
DRIVE: MD 180 TURBO W/ KICK-UP FINS + ARC CRANKS
LENGTH: 16' 7" / 5.05 M
BEAM (AMAS FOLDED IN): 44" / 1.12 M
BEAM (AMAS OUT): 9' 6" / 2.9 M
CAPACITY: 400 LBS / 181.44 KG
VANTAGE CT SEAT CAPACITY: 275 LBS / 124.74 KG
FITTED HULL WEIGHT: 102 LBS / 46 KG
FULLY RIGGED WEIGHT: 185 LBS / 84 KG
MAST LENGTH: 16' 6" / 5.03 M
SAIL AREA: 65 FT² / 6.04 M²
HULL CONSTRUCTION: ROTOMOLDED POLYETHYLENE
FLOOR TO AKA BARS: 18" / 45.72 CM
FLOOR TO BOW: 18" / 45.72 CM
FLOOR TO RUDDER: 27.5" / 69.85 CM
PostPosted: Fri Jan 29, 2021 7:38 pm
Specifications
Crew: 1-2
Width: 30" / .76 m
CREW: 1
Thanks. I gave up looking for a used one and ordered a new AI.
