It is currently Tue Sep 08, 2026 1:04 pm
 Post subject: delete
PostPosted: Tue Sep 11, 2007 7:21 pm
delete
HowieR6
 Post subject: AI cart
PostPosted: Thu Sep 13, 2007 6:21 pm
The tubes are 1"o.d. 12" width outside to outside. Crossbar is 7" below top of tube. The legs are ea. 14", the wheels are 9". The bottom of the boat sits on the crossbar and prevents the tires from rubbing the bottom of the boat. I mention this because one of my boats has the rub burns from wheels. I hope this gives you the info you need.
Bill
PostPosted: Thu Sep 13, 2007 6:28 pm
After reading that description, I was confused myself. Basically an H using 1" tube, then the axle is placed low enough so the tires don't rub bottom of boat. Vertical tubes are 14" and overall width of H is 12"
Hope this is better.
Bill
 Post subject: help appreciated
PostPosted: Fri Sep 21, 2007 8:05 pm
thanks for the dimensions
HowieR6
