It is currently Mon Aug 03, 2026 2:09 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 25, 2009 7:17 am
Authorized Hobie Dealer
we've changed a few out for customers in the past. I will be sure to make it a higher priority in the future!
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Mon Jan 26, 2009 12:34 pm
How is it done?
Is it a DIY job?
Ger
PostPosted: Mon Jan 26, 2009 1:16 pm
Pretty easy for DIY.
There is a tool available from Hobie #71115101
The cleat can be removed with pliers, cover with a cloth if you want not to damage it for reuse in the future. Turn CCW to remove.
Installing the eye (#71116001) is easier, I just used a long shaft screwdriver through the eye, turn CW.
Kayaking Bob
PostPosted: Wed Jan 28, 2009 2:15 pm
Ger wrote:
How is it done?
Is it a DIY job?
Ger
As Bob said they are easy to change. Needle nose pliers work well if you don't have the proper tool. Also checkout Roadrunners useful 'fun with fittings' post here:
http://www.hobiecat.com/community/viewtopic.php?t=8922
If you want a padeye instead of a cleat and you don't use the padeye's on the ama just swap them.
I do use the cleat for bungeeing the drive down when I am paddling in Adventure mode or sailing with the drive out when conditions are suitable.
They are also easy to modify. Here I have tapped a 6mm thread (remove the fitting first :wink: ) for a fitting an eyebolt:
PostPosted: Sun Feb 08, 2009 10:02 am
I like it!! That is using your head!
2010 Hibiscus Adventure Island
 Post subject: Re: What's this for"
PostPosted: Sat Jan 01, 2011 6:48 am
Whoa, your Islands came with a head???
I'm still trying to find the engine room on mine.
Island life in the Devil's Triangle:
http://2gringos.blogspot.com/
