It is currently Fri Aug 14, 2026 4:00 pm
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Aug 23, 2009 3:54 pm
If :)
New to PCs and this forum stuff. Had an original Outback and Classic. sold them both for the A.I.. Love the boat and especially this site... (if I can figure out how to use it)
PostPosted: Sun Aug 23, 2009 4:01 pm
Did a bit of experimenting on the water today. I have come to the conclusion that pedalling below 5 knots makes a sizable difference and will add a Knot to the speed. Over 5 Knots the improvement is less noticeable, but it will help it point higher.
Either lead, follow, or get the hell out of the way!
PostPosted: Sun Aug 23, 2009 4:44 pm
well -to each his own.I`ve been home with a root canal tooth gone bad an am in pain like you wouldnt believe for the last 6 weeks. Appointment tommorrow. F---. I could have bought an Adventure Island for what I paid these dentists. :evil:
PostPosted: Mon Aug 24, 2009 12:17 am
Tooth decay is just one side-effect of chewing your beetle nuts..... :? but I am sure we feel for you as most of us have had that pain...Good luck friend...Pirate :wink:
 Post subject: A SECOND DAGGERBOARD?
PostPosted: Mon Aug 24, 2009 8:57 am
Several AI owners have discussed using the Mirage Drive as a secondary keel-daggerboard
but have mentioned that analysis has shown that the 'flippers' interfere with each
others' hydrodynamic flow, when used passively.
Do you think that a second daggerboard installed on the portside, as a mirror of the starboard
daggerboard well would give better pointing?
My old C-Scow had two daggerboards and pointed very well.
Might a second daggerboard 'slot' be contemplated as an 'upgrade' for the AI hull when
new molds have to be made at the factory?
PostPosted: Mon Aug 24, 2009 10:03 am
I experimented with holding the pedals so the blades were at approx 45 degrees to vertical and that seems to work reasonably well offering some sideways resistance but keeping clear of each other helping with the turblence. I imagine that the right hand blade probably interferes with the dagger boards flow to some extent, but with all 3 in play, it seemed to hold its course reasonably well.
It would be interesting to do some proper flow tests with the blades at different angles to find the most efficient place for them.
PostPosted: Mon Aug 24, 2009 3:26 pm
Interesting discussion! 8)
I use a 6mm eyebolt to lock the drive in the fins down position:
viewtopic.php?f=32&t=10831&p=57071
You can lock the fins at about 45 degrees by choosing a 3 or 4 hole difference when inserting the eyebolt:
I'll have to try it next time I'm out! :wink:
PostPosted: Mon Aug 24, 2009 4:18 pm
Good one Stringy. Do you use the eyebolt to fully replace the Hobie bungy strap?...Pirate
PostPosted: Mon Aug 24, 2009 7:47 pm
I brush /floss religiously Pirate. And Im not even religious.
Ok-I lied about the flossing.But beetle nuts have nothing to do with my tooth problem.
You still havent answered the original post.
Bastard.
And its "Betel" nuts.
PostPosted: Mon Aug 24, 2009 9:13 pm
Stand fast everyone whilst Pirate takes a side. :D
PostPosted: Tue Aug 25, 2009 1:08 am
Sorry Aledal. What was the question?....Pirate :wink:
PostPosted: Tue Aug 25, 2009 1:09 am
No Pirate, I still use the bungee which does a better job of keeping the fins up tight against the hull. :)
PostPosted: Tue Aug 25, 2009 3:23 am
and can still be attached and used in shallow water thus limiting depth of fin. The pin is a handy idea all the same...Pirate :wink:
PostPosted: Tue Aug 25, 2009 4:53 am
Hadn't thought of that use for the bungee -to aid when fluttering in very shallow water.
Nice work Pirate! 8)
Now that's definitely one for the pool room! :wink:
PostPosted: Tue Aug 25, 2009 11:20 am
The question is at the beginning of the thread...
Where all threads begin.
I was just interested ... in... your....
oPINion
AAaarrrg aaaghh aag arrggg :lol:
