It is currently Sun Aug 09, 2026 12:26 pm
Post new topic Reply to topic  [ 131 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Fri Dec 05, 2014 6:08 am
The explanations are very helpful, I feel a lot better about the handle change now. It makes sense to me that with all the variables not everyone has experienced the funneling problem. If needed, a surface applied handle may be a better solution.
thanks
- chris
PostPosted: Fri Dec 05, 2014 6:34 am
fusioneng wrote:
I suspect the water funneling problem was mostly on the AI which sat much lower in the water compared to the TI. I honestly never experienced any water funneling.
Bob
Bob, I've never known any AI owner to complain about water funneling off the handles. I have always thought it was a TI problem. Stringy, help us out here.
PostPosted: Fri Dec 05, 2014 10:17 am
Here is 29 pages of comments related to wet rides on the AI and TI.
http://www.hobiecat.com/forums/search.php?st=0&sk=t&sd=d&sr=posts&keywords=wet+AI&fid%5B%5D=67&start=420
A primary focus was to eliminate as much potential water into the cockpit as possible.
PostPosted: Fri Dec 05, 2014 12:55 pm
Chekika wrote:
Bob
I'll go on record here, I have a AI and water does funnel off of the handles.
Personally, I think that Hobie knows a lot more about designs and funtionability about Kayaks then I'll ever know and am willing to let them figure this inconvienience out.
I live in So.Cal and for me, as an ex surfer and Hobie Cat sailor, I enjoy the wet ride as it's part of the water dawg experience that I like.
PostPosted: Fri Dec 05, 2014 2:07 pm
Keith,
The water funneling problem began when Hobie added the molded handles.
So all TI's and AI's (from '10 onwards?) have the problem. It is worse on the AI because it sits lower in the water. I noticed it on my first trip to work in my warranty replaced '11 AI hull (kayak mode). On what would normally have been a dry ride I ended sitting in a seat well puddle. The issue was not there in my '08, '09 hulls without the side handles.
Here is a short clip of the problem. This was taken in calm conditions but our TI was loaded up for camping. Any chop that hits the handle area is directed into the seat well
Here are a couple of early posts. The first gives a bit of an insight into how the problem arose. It seems the new handles were tested on the TI but not so much on the AI.
viewtopic.php?f=75&t=35009
Slaughter posted a fix which has worked well. I'm still using it on the AI. The foam has weathered a bit and I'm now using shadecloth rolled around the bungee, which also works.
viewtopic.php?f=69&t=35258&p=142453
What I had hoped for from Hobie was a fix for the water funneling and not the handles removal. :roll:
PostPosted: Fri Dec 05, 2014 2:47 pm
mmiller wrote:
The handles were well tested on the Tandem Island since last year, but that boat is a little higher... same issue though. We are looking at foam plugs or flaps to divert water and not block the intend use. They are nice for holding while pedaling too.
Matt,
As you know I consider removing the handles a cop out and a backward step.
The positives with the handles far outweighed the one negative. An AI/TI is always going to be a wet ride. The new raised mesh seats and remote venturi drain have made the water funneling less of an issue.
I'm a bit worried about what is going to happen with the Revo16. The water funneling is a real problem with this hull as well. Are the handles remaining on it? I would hate to see them removed. Yet I would also like to see a factory fix for the splashing. One that didn't involve the handles disappearing.
What are the chances of a proper fix on the Revo 16?
PostPosted: Fri Dec 05, 2014 2:57 pm
Stringy, nice video that illustrates the problem. I've always had the seats on our AIs elevated some with foam and, the last couple years, with the I-seat (i.e., the inflatable seat--both comfortable and "wet puddle" free.) I see the splash in the video, and it probably occurs on our AIs, but we have just never noticed it. Obviously, we have not considered it a problem.
PostPosted: Fri Dec 05, 2014 3:05 pm
"No problem ma'am"
PostPosted: Fri Dec 05, 2014 3:58 pm
Well my 2009 AI never water spouted like that
Every day is an Adventure Island day
PostPosted: Fri Dec 05, 2014 4:51 pm
I'm sure the handles remained on the Revo 16 (name only conversion). The boat does not have the speed or heeling that causes the issue under pedals alone.
PostPosted: Fri Dec 05, 2014 6:40 pm
Thanks Matt, but those handles still funnel water onto the seat in Adventure kayak mode. The '11 hull, just pedaling or paddling in the slightest of chops, is a much wetter ride than the earlier handle-less models. You don't need to be going fast or heeling for the seat to get soaked. Where the '08 and '09 hulls would remain dry, in the '11 hull in the same conditions you end up sitting in a puddle.
Don't get me wrong but if the only fix is handle removal I'll put up with it ...there are workarounds and it will be less of an issue with the new seats.
However as this problem has been known by Hobie since at least 2011 I'm surprised and disappointed that the only factory fix seems to be get rid of them entirely. :?
PostPosted: Sat Dec 06, 2014 5:05 pm
Yeah, we tried to get the foam handles modified. Two vendors and no luck with the design we had in mind. May still happen. Likely you saw the images Jacques posted about it some time ago?
PostPosted: Sat Dec 06, 2014 8:07 pm
Yes, thanks Matt. I've been looking forward to the updated handles since 2012! :roll:
For those newer members that may be wondering why all the fuss about the handles, the post that the pic is from makes interesting reading. Especially in the light of Hobie's 'fix' for the water funneling handles on the Islands.
In all fairness to Hobie they have tried a solution but when the vendors had problems it looks like it just got too difficult. :?
viewtopic.php?f=71&t=44612
PostPosted: Sat Dec 06, 2014 8:24 pm
I happened to take a visiting friend out today, and took advantage of the opportunity to video the handle. Here is a 50 sec video of the handle while sailing in 1-1.5 ft chop.
Yes, there is funneling--first time I ever noticed it.
PostPosted: Sat Dec 06, 2014 8:52 pm
Keith,
Maybe the reason you never noticed it before is due to Florida's heat and high evaporation rates! :wink:
Here downunder I was aware of it on my first trip in my new '11 hull, which was in kayak mode.
In the calm conditions I hadn't undone the seatwell drains (as I'd never needed to before) and I was sitting in a puddle by the time I got to my destination. I was only paddling, yet due to the chop I was as wet as if I'd been sailing the AI at speed!
