It is currently Sat Aug 15, 2026 2:39 am
PostPosted: Thu Jul 30, 2009 11:58 am
Being new to all this, I am getting to grips with the various differences between models. Am I right in thinking there are just 2 versions of the Mirage drive? I have just read Roadrunners excellent maintenance section in the tips section. In his pictures there appear to be 2 quite different systems, presumably version 1 and 2. I want to order some Tubo ST's for mine and want to make sure I order the right parts.
The first photo appears to have metal sprockets, so I assume is version 1
The second photo looks to have screw in masts and plastic sprockets, so I assume is version 2
I would appreciate someone confirming this please. I appear to have the V2 on my AI.
Thanks.
Either lead, follow, or get the hell out of the way!
PostPosted: Thu Jul 30, 2009 12:17 pm
There have been 3 versions.
(1) Original Drive had stainless sprockets and an aluminum spine.
The drive was changed in many ways with the addition of plastic molded parts to reduce weight and inprove our ability to make them.
(2) The 2nd version is primarily identified by the sprocket's mast retention system. Early sprockets used set screws to hold the mast in place.
(3) "V2" drives have evolved over the last 2 years. First with V2 drums and new cables / chains. Last summer we added the V2 sprockets and threaded masts.
PostPosted: Thu Jul 30, 2009 12:43 pm
Thanks for explaining that Matt, I now have a much clearer understanding.
If I have the middle version with the set screw securing the mast, which seems likely. If I wanted to upgrade to the latest setup with the screw in mast, is it a case of simply buying the later sprocketsand fitting them into mine. I am aiming to fit the Turbo ST fins which will come with the longer mast, will I need to buy anything else?
PostPosted: Thu Jul 30, 2009 1:20 pm
Just the two new sprockets and the V2 Turbo kit.
PostPosted: Thu Jul 30, 2009 2:01 pm
Excellent! Thanks for the advice.
