It is currently Mon Aug 10, 2026 11:39 pm
 Post subject: control lines
PostPosted: Sat Dec 19, 2009 4:48 pm
how do you keep your main sheet and furling lines where you need them? Mine end up where I can't reach them, over-board or tangled up in the mirage drive.
 Post subject: Re: control lines
PostPosted: Sun Dec 20, 2009 10:46 am
A good start is to tie the ends of the furling line and mainsheet together. Keeps them in reach, and mostly where you want 'em.
PostPosted: Sun Dec 20, 2009 11:15 am
I have fitted a longer furling line and run it through an eye I have mounted over the rudder downhaul and simply tie a knot in the end of it. This keeps it within easy reach. I have fitted a caribiner to the eye that you run the dagger board elastic through and run the mainsheet through the caribiner with a knot in the end. Again, always within easy reach.
Either lead, follow, or get the hell out of the way!
PostPosted: Sun Dec 20, 2009 1:01 pm
Like Joseph Thompson said:
A permanent loop in the sheet line, to tie the reefing line to.
Also, used to keep the lines tight during transport:
