It is currently Thu Aug 06, 2026 5:14 pm
PostPosted: Fri Jun 18, 2010 12:07 pm
Matt
I have a small crack on top of the bow from the rear screw on the front pull handle. It's on the port side, the starboard side appears to be Ok. The crack is about 1/2" long and ~1/32" wide, looks like it's originating from under the eye strap screw hole. It doesn't appear to be all the through the hull, I've run water over it and no leaks inside. I can see the two bolts covered in plastic that hold the screws for the front screws. Should I be concerned? Wondering if I should melt yellow repair plastic into the crack or leave as is. Hull number is CCMD7397H809.
I'd appreciate your input.
Bob
PostPosted: Fri Jun 18, 2010 12:45 pm
The handle screws are threaded into a single piece molded into the hull, so not likely to pull out easily. I would do something about the crack so it doesn't expand. Something stressed this handle? You don't hang the boat from it hopefully?
PostPosted: Fri Jun 18, 2010 12:56 pm
Matt
It's hung upside down in garage on Harkin straps, nothing comes in contact when stored. I use Wheeleez cradle with floatation tires (2 sets) when I pull AI down and up the beach. It is a tuff pull at times, that's why I have two sets. It's like pulling a wagon.
PostPosted: Fri Jun 18, 2010 2:37 pm
I would try a little weld.
PostPosted: Mon Oct 04, 2010 8:20 pm
fyi - I reported this exact same problem to my dealer yesterday with my 2009 revo. I have no doubt it will be handled properly(Love Hobie kayaks). Again never any stress on the handles from me.
I bet it looks just like this:
PostPosted: Tue Oct 05, 2010 8:31 am
That is exactly what my crack looks like! Same screw and side.
Bob
PostPosted: Thu Oct 07, 2010 2:57 am
Hmmm... I'd wonder if it's a glitch in the roto-moulding process? I'm no engineer, but I bet it's difficult to get the same thicknesses exactly where needed every single time, for the designed strength.
PostPosted: Fri Oct 08, 2010 7:09 am
Matt, do you have a max load specification for this handle?
I often wonder how strong the AI is in this area when I'm pulling it up and down the sand on my wheeleez cart. Sometimes the pull is pretty hard through dips in the sand etc.
Thanks,
JJ
PostPosted: Fri Oct 08, 2010 8:23 am
There is no "load" rating.
PostPosted: Sat Oct 09, 2010 4:03 am
if this were mine, and both Hobie and the dealer were not going to warranty the issue ...
... I would look to terminate the crack by drilling a hole at the end(s) with a countersink bit before using the weld material - this radius's the ends of the crack and usually provides a relieve for any kind of stress crack. The diameter of the hole should be several times the width of the crack
Alan W.
.. and a Hobie Outback SUV
