It is currently Fri Aug 07, 2026 11:40 am
PostPosted: Sun Mar 13, 2011 2:33 am
Hi guys,
A couple of simple ones:
1: What is the diameter (mm) of the AKAS bars?
2: What is the grade/type of alloy they're made from - and is it 'weldable'?
Cheers,
Mike.
PostPosted: Sun Mar 13, 2011 3:48 am
the first one is simple
1. 50 mm.
I suppose the second one is easy too
2. havent got a clue! :D (sounds like one for Matt & Co.)
Hobie Adventure Island (Yellow Papaya)
Hobie Tandem Island (Yellow Papaya)
PostPosted: Mon Mar 14, 2011 5:22 pm
The original akas are welded, so... yes, weldable. We usually use 6061 T-6
PostPosted: Mon Mar 14, 2011 7:52 pm
About 1 5/8" OD for you Yanks.
The Wind Is Your Friend...
PostPosted: Mon Mar 14, 2011 7:56 pm
Hmm...
So are they 50mm, or 41mm (1 5/8")? :-)
I need the external diameter of the tubing, as I'm trying to design a mounting plate to fit a Scotty #241 deck mount... It'll be welded to the AKAS cross-member (behind the seat).
Cheers,
Mike.
PostPosted: Mon Mar 14, 2011 8:16 pm
My 2007 AI Aka tubes (not the crossbars) are 1 5/8" OD, therefore 41mm.
That's a center round reading, and due to stamping they will vary in shape as you move out toward the ends.
cron
