It is currently Sat Jun 13, 2026 10:48 pm
 Post subject: Mast Carrier
PostPosted: Wed Mar 16, 2011 8:08 am
Has anyone made a mast carrier for the AI or TI? I'd like to build a carrier for transport that would support the mast horizontally slightly above the boat.
 Post subject: Re: Mast Carrier
PostPosted: Mon Mar 28, 2011 3:00 pm
I had the same idea. Check out "Yakima MultiMounts" for paddles, masts, etc. Yeah, they're designed for Yakima roof racks, but I imagine they could somehow be fitted to the boat without too much effort. Thule used to make something called the "Thule 839 Get-A-Grip Mast & Canoe/Kayak Paddle Holder", but it's no longer available. Too bad, it had locks for the holder AND the mast! It was PERFECT. I don't know why they stopped making it. You might also try a rifle rack typically used on 4-wheel ATCs, but you'd have to get your own stainless steel nuts & bolts, as these aren't marine-rated.
RC
Houston, TX.
2010 Golden Papaya TI, "Trifurcatus"
Image Image
PostPosted: Fri Apr 01, 2011 5:35 am
I use a thule mast carrier, it bolts straight up onto the aka mounts that are fitted to the main hull (tandem island 2010). It is handy for transporting masts when travelling on the car and also when the mast is taken down on the water for passing under low bridges etc.
PostPosted: Fri Apr 01, 2011 9:16 am
Did you know the part number for the Thule mast carrier?
Thank you
PostPosted: Sat Apr 02, 2011 1:20 pm
Thule 855
http://www.thule.com/en/AU/Products/Wat ... 20855.aspx
PostPosted: Sun Apr 03, 2011 8:40 pm
I like the Thule mast carrier, however it's not on the Thule US website. Not sure why??
Where did you buy your's?
PostPosted: Sun Apr 03, 2011 10:32 pm
Off the shelf in Australia....thule seem to stock different ranges in different countries....but their dealers can get what you want....there are internet sales dealers also (in Australia anyway)....just google.
PostPosted: Wed Apr 06, 2011 1:35 pm
The Thule 839 Get-a-Grip Mast Carrier is available from REI in Seattle, Washington. You'll have to call the Seattle store directly because these items are no longer available on their website. There are several REI stores in the Seattle area, but I think the number for the specific store is 206-223-1944. At the time of this writing, they have 5 pairs in stock, and they're CHEAP... about $11.00 for a box of two.
RC
Houston, TX.
Image Image
PostPosted: Sat May 07, 2011 1:35 pm
Thanks for the heads up. I had been looking for this item. I just bought their last two.
- Fireseid
Running a 2010 Tandem Island transported on a modified Yakima Rack & Roll.
Modifications: Torqueedo Hobie eVolve v2; Furling line rigged to cleat from rear crossbar w/Spinlock cam cleats; Custom ACK anchor trolley system;
