It is currently Thu Aug 27, 2026 11:41 am
 Post subject: Difficulty steering
PostPosted: Mon Jul 16, 2012 3:22 pm
I took my AI out last weekend for the first time this summer and I had a lot of difficulty steering. I had to use two hands to stay on course and I had to use so much force that I had to turn around and come back to shore. The difficulty was equal on both tacks. I did not have the same difficulty before. Steering lines to rudder are both taut and tiller moves rudder easily with no wind load on boat. Anyone else run into this problem? Any ideas or suggestions? Thanks, William.
 Post subject: Re: Difficulty steering
PostPosted: Mon Jul 16, 2012 3:58 pm
Did you have the rudder pulled down tight and cleated? Was the wind very strong and if so, did you furl the sail a bit?
PostPosted: Mon Jul 16, 2012 6:02 pm
Nice pic :) Yes it was down and cleated and the wind was not strong enough to require reefing.
PostPosted: Tue Jul 17, 2012 10:25 am
Gris. This is exactly the symptom you would see when the rudder begins to slip up (becomes more horizontal than vertical). That indicates a cleating problem.
If not, then your tiller arm may be binding on the hull or something else (the spring or pulley) when it's under load. It may be bent or loose.
Time to take out the hand mirror and trace things. Use a can of lube on all friction points
PostPosted: Tue Jul 17, 2012 11:18 am
Two of you, and also a Hobie employee, have now all said the same thing- that the rudder was not cleated properly. I am beginning to doubt whether in fact it was. I hope that was the problem. I will give it another go and will let you know the results. I will also try some lube too. Thanks for the input! Cheers.
PostPosted: Tue Jul 17, 2012 11:35 am
One other thing. If you have a hull with a cleat for the rudder up-line, make sure the up-line is free of the cleat.
