It is currently Tue Aug 25, 2026 11:19 pm
 Post subject: AI Lee helm
PostPosted: Wed Dec 12, 2012 12:48 pm
The 2012 rudder system is a big improvement on my 2009 system that broke pins. However I have had a light but annoying lee helm issue ( boat naturally pulls away) that makes me point low when not concentrating, which is most of the time.
I raced Hobie 14s in the 70s and recall the huge weather helm issues with the boat when new, This was common with Hobies although there was a fix. You needed to get the rudder tip forward to change the balance. The dealer had a setup where he plugged and redrilled the radius point in the rudder blades that kicked the rudder forward about 15mm. The difference in steering was amazing I went from mid fleet to lead pack.
Applying the same principal to my AI I glued a little rubber bumper to the rudder housing so the rudder tip went aft about 10mm - bingo slight weather helm. Now the boat sails itself to windward and is well balanced.
Hobie could work out where the correct radius point is to achieve the correct balance ie slight weather helm.
If your boat does as mine did stick a cupboard bumper in as a packer and feel the difference.
Happy Sailing
 Post subject: Re: AI Lee helm
PostPosted: Wed Dec 12, 2012 10:35 pm
Dave, you description seems contradictory (or I am screwed up LOL)
In your second paragraph you say to get the rudder tip forward. but in the next paragraph, you say that the mod moved the rudder tip AFT 10mm. Which is correct?
PostPosted: Wed Dec 12, 2012 11:58 pm
Hi Tony
As I said my cat had weather helm and my AI had lee helm that's why.
Cheers
Dave
PostPosted: Thu Dec 13, 2012 3:55 am
Gotcha.. sorry for not paying attention LOL
PostPosted: Thu Dec 13, 2012 9:09 am
Adjusting the angle / depth of the dagger board can change steering feel as well.
I don't think it is typical for the AI to have Lee helm that can not be overcome by the dagger board, drive fins position or sheet tension.
Anyone else having the issue when using the new larger rudder system?
PostPosted: Thu Dec 13, 2012 9:32 am
I don't even think about the new rudder. I guess that means it is working great!
PostPosted: Fri Dec 14, 2012 7:57 pm
I've noticed a bit of lee helm with the new rudder too, as I posted previously:
viewtopic.php?f=71&t=44312&p=187737
I wouldn't call it an "issue". I find the slight lee helm with the new rudder blade a lot less of a bother than the strong weather helm with the old blade. (Though it sounds like Dave's mod improves things even more.)
PostPosted: Sun Dec 23, 2012 11:04 pm
Off topic but how did you install a 2012 rudder system on a 2009 Hull? I thought this wasn't possible.
PostPosted: Mon Dec 24, 2012 12:20 pm
You can't.
But some of us had the newer hulls that shipped with the older twist-style rudder. These could be swapped out with the new up-down rudder.
Now that I think about it, there may be a slight lee helm on mine.
PostPosted: Mon Dec 24, 2012 1:53 pm
I had my 2009 hull replaced in 2011 due to crack in scupper.
I should add that the AI is a great boat and I love it.
The rubber bumper I fitted on the rudder blade is about 10mm thick and is positioned at the contact point with the rudder housing. It has had a minor change to the helm and is an improvement in my case.
Ferrari's need minor adjustments OK
