It is currently Mon Aug 10, 2026 4:03 pm
PostPosted: Thu Aug 20, 2015 8:36 am
I have a 2014 tandem island and lately the rudder will not come all the way up. I pull the up chord and it goes about 1/2 way and then stops. Does this mean the adjustment slipped? Also, it seems harder than I remember pulling the rudder up.
Rudder down works as it always did....
PostPosted: Thu Aug 20, 2015 10:05 am
My TI is newer so the lines are less stretched out than yours might be, but one trick I use is to pull the front seater UP line out about a foot and cleat it, then finish the job with the back seater UP line. It does take a good firm pull to get the rudder past level and fully up.
PostPosted: Thu Aug 20, 2015 11:05 am
Check the shock cord, pulley or limiter line to make sure one of them isn't getting tangled in something else that would prevent the line from freely moving.
Personally I just eliminated the front controls and reran the line for the back seat only. This allowed me to eliminate the extra pulley, the shock cord and that silly limiter line crossing over. Made it all much simpler so if something goes wrong on the water it could be an easy fix. Could also eliminate the back seat control and do the same if your a front seat solo rider.
I did the same for steering.
Also I ran all the lines within plastic tubing to eliminate/slow down any water entry from the rudder lines. Out all day yesterday in rough wind, sailing alone on TI, no more than a pint of water in hull afterwards. 8)
See pictures and especially Matt's diagram for an idea of what your looking for.
viewtopic.php?f=75&t=53903&hilit=TI+rudder+diagram&start=15
Mark
Tandem Island- 2013
2 - Sports - 2014
Users browsing this forum: Bing [Bot] and 2 guests
