It is currently Sun Aug 09, 2026 4:53 am
PostPosted: Fri Sep 04, 2015 2:42 pm
I am guessing that the pad eye in the AI2's cockpit is intended for attaching the Mirage Drive's leash.
viz: https://picasaweb.google.com/1081497986 ... 3275899570
OTOH the pad eye is plastic and the Mirage Drive is pretty heavy....
I am thinking more like the fore iako receptacle as per:
https://picasaweb.google.com/1081497986 ... 6987739634
What do most people do?
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Fri Sep 04, 2015 2:56 pm
On the TI, the padeye near the twist and stow is to store the bungee which is used to hold the starboard mirage drive peddle aft to keep the fins close to the hull. You can make running bowline in your leash and attach it to the aka crossbrace which is what a lot of people do.
The forward bulkhead (beneath the aka crossbrace) on the TI has a padeye which can be used for the leash, but the aft bulkhead does not.
PostPosted: Sat Sep 05, 2015 9:51 pm
I've been meaning to install a padeye for leash attachment on the forward bulkhead of the rear position of the TI, but an thinking a couple screws to hold it with ought any backing would be inadequate. Would well nuts that expand on the inside work well? Certainly can't get my hand up in there from inside...
~BoP
PostPosted: Sun Sep 06, 2015 2:51 am
Surely it is a no-brainer to just tie a loop of line around the crossbar with a snapshackle on the end, to hook to a small loop on the Miragedrive. You can then, by selecting appropriate strength of line, guarantee that you won't lose your drive.
PostPosted: Sun Sep 06, 2015 5:38 am
That is the solution that I thought was the most logical - but I keep coming back to wondering if there is some specific purpose for that padeye next to the fore hatch.
PostPosted: Sun Sep 06, 2015 6:05 am
I don't know how you can sleep Pete, with all these mysteries afoot! :D :D
PostPosted: Sun Sep 06, 2015 6:52 am
Is it not for storing the bungee hook that otherwise holds the starboard mirage peddle aft when not peddling?
PostPosted: Sun Sep 06, 2015 7:20 am
I know I am spending way too much time obsessing and not nearly enough time on the water.
On Tuesday, the third box for the trailer arrives and the auto tag place re-opens. ..... The damaged-in-shipment part is supposed to arrive on Wednesday.
So, by the end of next week I should be shutting up.
PostPosted: Sun Sep 06, 2015 7:22 am
It could be, but the bungee would cross the twist-n-seal hatch cover if used for that purpose. Assuming it is not put there to mystify some people, use it for anything you want. For example, it could be used, as I do, to tether my bilge hand pump which I store under my Vantage seat. You could also attach a more secure tether for your Vantage seat, or you might tether a small dry bag with foul weather clothing, or tether the Mirage drive, or....
PostPosted: Sun Sep 06, 2015 10:36 am
No need for shutting up Peter! All the conversations are good, as there is always someone else following on who can benefit from the discussions.
PostPosted: Sun Sep 06, 2015 4:15 pm
tonystott wrote:
..... there is always someone else following on who can benefit from the discussions.
That has always been my own rationale - building a sort of database for those who follow.......It is nice to hear thar I am not the only one..... Thanks.
PostPosted: Mon Sep 07, 2015 5:49 am
You can obtain some very small SST quick links that are stronger and less bulky than the smallest aluminum carabiner. I'm using them on my mirage drives and seat leashes. As others have said it's easy to just loop around the aka crossbars and secure the line to itself with the quicklinks.
Chris
PostPosted: Mon Sep 07, 2015 5:57 pm
I use it for storing main/clew when sail de rigged as it was when I got it?
2015 Tandem Island - Golden Papaya "HALIBOO"
(retired) Outback - Hibiscus Red
PostPosted: Tue Sep 08, 2015 4:25 am
As others stated,on my TI I also just rap the leash around the aka bar to hold the rear Mirage drive.
For the pad eyes next to the hatches , I use them to attach my electronics or small dry bag while on the water. When traveling, I use them to hold the seats in place with a bungee, so the won't fall off going down the road. I don't think you would want to use them for mirage drive leashes, I would think the leash would get in the way while pedaling or even worse, your foot getting caught.
2015 Hobie Tandem Island
