It is currently Fri Aug 07, 2026 12:16 pm
PostPosted: Thu Oct 08, 2015 12:24 pm
I never have... seems like it has little utility for me...
OTOH, my sailing so far has been limited to chop-less conditions.
OTOOH, it's wart on the bottom of the hull contends with bunks and it's more (not much more, but still...) junk hanging down into the slipstream.
I am tempted to remove it and plug the hole.
Illumination from Those Who Know ?
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Thu Oct 08, 2015 12:29 pm
If you're referring to the venture drain in the seat wells, I use mine all the time. Even though the vantage seats get you up and out of the seat well the cockpit can still fill with water if you're plowing through waves. I normally just leave it open while I'm on the water and then close them when I put the boat away. Trust me it is a welcome change to when you had to sit in a puddle of water. I haven't had any problems with it on the cradles and I have pre-2105 cradles. I have heard folks had issues with it when doing PVC bunks. I think the answer to that was just to heat the PVC in the area that the drain rests and create and indent for it.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Thu Oct 08, 2015 2:00 pm
Mine are pretty much permanently open. I forgot about them a few times when I first had the TI, filled the seat well with water - this was in March or so when the water was still quite cold - wondered why my butt was so cold even in a wetsuit. Realized I had forgotten about the drain and there was enough water in the well I was just touching it in the center of the seat!
Finally just cleated 'em and forget them.
Thought about removing them completely, but did actually have one time recently I wished I'd have closed them. I took the TI out in Kayak mode in perfectly calm conditions. Didn't need to drain anything, and having them cleated I got a splash of wet from below when I plopped down into the seat right as I got started! :lol:
PostPosted: Thu Oct 08, 2015 10:49 pm
I removed mine when I picked up the boat at the dealer and haven't experienced any problems. Gravity is still working where I live, but maybe they need them in the antipodes. :lol:
Chris
PostPosted: Fri Oct 09, 2015 12:59 am
I left the venture drain attached to the hull, but removed the cord and plug, so it is always open.
2021 Dune Hobie Lynx
PostPosted: Fri Oct 09, 2015 8:31 am
OK as long as the way your boat is loaded the floor is above waterline... otherwise water floods in. Most models are expected to have the floor lower that waterline. Then the plug and Venturi are critical for draining.
PostPosted: Fri Oct 09, 2015 8:08 pm
Even fully loaded for camping and fishing, the floor is above the water line on my AI.
PostPosted: Fri Oct 09, 2015 11:02 pm
I didn't feel that I needed it but always compelled to tinker with stuff I took the speed drain ball and hung a fishing weight on it covered with shrink tubing. The idea being that the loose seal caused by the weight still allows water to leak out and partially blocks little of surges of water coming up from below. I have no idea if this does anything useful since water in the seat well is a non problem for me.
I did find that the insert that previously held the drain handle in place is a handy location for a screw in padeye. I clip the leash for my phone on it and can drop the phone in the nearby mesh pocket.
Chris
