It is currently Tue Aug 04, 2026 5:58 pm
PostPosted: Sun Mar 20, 2016 3:19 pm
I am mulling over options for better furling control - and some of them involve a cheek block on the xbar.
In the interest of not drilling any more holes in the xbar, has anybody found a cheek block whose mounting hole spacing is the same as the Harken Mico Cam-Matic cleats already mounted on the xBar?
The mounting hole distance in question seems to be 27mm (1 1/16").
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Sun Mar 20, 2016 7:23 pm
I use the Harken 29c, it's really close but you need to elongate the holes in the block, I used an 1/8" drill bit and drill to do so....
PostPosted: Sun Mar 20, 2016 7:37 pm
Thanks! That's what I was trolling for...
Looks like Harken=30mm and existing holes = 27mm.... so you elongated one of the Harken holes by 3mm...?
Or did you elongate each hole about 1.5mm?
PostPosted: Sun Mar 20, 2016 9:41 pm
A little on both but more on the hole that's not in the middle of the pulley
