It is currently Fri Jun 12, 2026 6:26 am
 Post subject: Cradles for 2015 AI
PostPosted: Tue May 24, 2016 7:53 pm
I am on the verge of purchasing a 2015 AI and trailer. I was told by a very reputable dealer this weekend that for cradles for the 2015 AI using the Hobie designated Trailex trailer, this dealer uses the tandem island cradles instead of the cradles designated by Hobie for the 2015 AI. He said the tandem cradles work better than the ones for the AI. Does this sound right?
 Post subject: Re: Cradles for 2015 AI
PostPosted: Wed May 25, 2016 3:04 pm
They are similar. Better? Not likely but would work.
PostPosted: Thu May 26, 2016 9:28 am
Thanks for the prompt reply Matt. I assume from your wording that although the tandem cradles would work the cradles specified for the AI 2015 would be a better fit. I'm thinking about how the boat would best slide up onto the trailer and cradles from the water at a boat ramp. Thanks again.
PostPosted: Thu May 26, 2016 10:52 am
If you go with the AI cradles make sure you get supplied the VERSION #2 2015 AI cradles, my dealer didn't know about the Hobie 2015 Cradle Upgrade offer so I have the original ones which have no support cradles for the front of the AMA's. They work but I woudnt want to trailer it a long distance or on a bumpy road.
Thanks to Matt, this part number and advice. http://static.hobiecat.com/item_attachm ... hAShSo.pdf
Fair Skies, Max.
PostPosted: Fri May 27, 2016 1:40 pm
Thanks Skymax. I'm trying to avoid the mess you got into with your cradles, due to no fault of your own.
