It is currently Sat Aug 08, 2026 8:04 am
PostPosted: Tue May 31, 2016 6:07 am
Okay, so I learned the hard way this weekend that it is a good idea to use blue Locktite when replacing Mirage Drive fins (good thing they float), or in my case, replacing a bent shaft. So, the question is: How much? Just a bit at the end of the shaft, or a generous coating all over (bearing in mind that they'll probably have to come off again in the future for some yet to be discovered reason.
Thanks in advance!
PostPosted: Tue May 31, 2016 1:45 pm
Thanks in advance!
I am confused... You didn't mean applying Loctite to secure the fins to the shaft did you? You actually WANT the fins to be free to rotate around the masts,. as a fundamental part of the design of the Miragedrive.
I believe you should use Loctite on the threads on the metal masts only.
PostPosted: Tue May 31, 2016 9:38 pm
You don't need much loctite. Just a midge around the threaded part is all you need - a drop or two is fine.
Tony, he is referring to where the mast threads into the sprocket.
Kayak Fishing Specialist: SLH
https://slhobie.com.au
PostPosted: Tue May 31, 2016 9:58 pm
you can straighten bent mast you dont need to replace them
PostPosted: Wed Jun 01, 2016 5:07 am
I know that Josh, but the way he wrote it suggested he was asking about putting loctite "all over" the unthreaded part of the mast
PostPosted: Wed Jun 01, 2016 4:48 pm
This is true, although they can only be bent back into shape so much before the steel is weakened considerably. Sooner or later (most usually a lot later) they really should be replaced.
Tony I hadn't considered if he meant putting loctite over the entire thing (hehe), but re-reading it, yeah I can see how you read that into it.
PostPosted: Thu Jun 02, 2016 7:10 am
What Yakass said. Sorry for the confusion and thanks for the help!
