It is currently Sun Aug 02, 2026 3:09 pm
PostPosted: Wed Jan 11, 2017 11:48 am
I'm doing my wiring for a fish finder and my transducer cable has a section on it that is slightly too large for the Hobie thru-hull kit. I need maybe another 1/4" to 1/2". Any options out there for a clean install?
PostPosted: Thu Jan 12, 2017 4:56 am
Is the 3 way version a bigger hole than the two way kit?
PostPosted: Thu Jan 12, 2017 6:12 am
kayaddict, what kayak and what ff??
2015 Tandem Island - Golden Papaya "HALIBOO"
(retired) Outback - Hibiscus Red
PostPosted: Thu Jan 12, 2017 7:40 am
I have a Tandem Island and I'm installing an Lowrance HDS-7. The issue is the 3d structure scan transducer. On that transducer cable is a box that looks like http://ep.yimg.com/ay/wmjmarine/navico-transom-mount-transducer-for-structurescan-3d-000-12396-001-9.gif . The box is the where the cable coming from the transducer splits its signal into 2 other wires. That box is 1.14" wide which means to fit through a hole it needs to be somewhat larger than that.
I found this product https://www.amazon.com/gp/product/B000MMH1B2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 and just went ahead and ordered it. It will support cable fixtures up to 1.4" wide so it should work. I'll post back here once I get it installed.
PostPosted: Fri Jan 13, 2017 11:56 am
I see, I have the plain Lowrance Elite 7ti which is similar but only one transducer plug? Sorry, was hoping to help but will be interested in your solution. Good luck. H
