It is currently Sun Jun 14, 2026 3:06 am
PostPosted: Wed Jan 18, 2017 7:44 am
My current strategy is to use my single-bladed paddle as a steering oar or steering paddle.
I've tried this a few times in light air and it seems to work... more-or-less.... mostly less...and I have doubts about heavyier air.
Has anybody got another approach that works for them ?
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Wed Jan 18, 2017 10:58 am
Add a set of external lines to your rudder to use in situations like a broken line, or, more likely a line that has slipped loose at its rudder connection.
PostPosted: Wed Jan 18, 2017 11:04 am
Are you doing that now?
If so, got any pix ?
I'm thinking nicities that the likes of me would never come up with....
PostPosted: Wed Jan 18, 2017 1:31 pm
A motor and/or keep plenty of pins available to replace in rudder. Simplify rudder lines so no entanglements are not possible. That about covers all scenarios here.
Mark
Tandem Island- 2013
2 - Sports - 2014
PostPosted: Wed Jan 18, 2017 2:14 pm
See Tony's very nice solution found here:
viewtopic.php?f=71&t=58913&p=280154
As CR says that is another benefit of adding a motor. I have steered with my motor quite a few times since fitting it as draws a lot less than the rudder.
PostPosted: Wed Jan 18, 2017 3:25 pm
Pete, I've posted a description of my external rudder lines here.
http://www.hobiecat.com/forums/viewtopic.php?f=70&t=7276&p=285133#p285133
Not nearly as elegant as Tony's but similar.
PostPosted: Wed Jan 18, 2017 6:34 pm
I really like Hajime K's steering system, not as a backup but instead a replacement for the tiller in some situations. Haven't tried implementing it yet though.
https://www.youtube.com/watch?v=kmokGcagtJk
It's been brought up here before as well, just one comment from someone who uses the system. He said it was about $100 in parts:
viewtopic.php?f=71&t=57060&hilit=hajime
PostPosted: Wed Jan 18, 2017 7:51 pm
I had a good look at that system and have the following observations
1. It does not appear practical for steering when seated in the seat, and inoperable from the rear seat
2. I believe the steering system would become unusable if an ama is folded
PostPosted: Mon May 29, 2017 4:33 pm
FWIW, I think I have a solution: https://www.hobie.com/forums/viewtopic.php?f=71&t=60647
Works like a charm with no rudder, but next time out I will test it with the rudder jammed in hard-right or...left position - and not exppect it to work....
