It is currently Thu Aug 06, 2026 7:05 pm
 Post subject: Vantage seat adjustment
PostPosted: Sun Aug 20, 2017 9:24 am
I have a TAI, and the front adjustment rod to lower /heighten the front of the seats are frozen and will not move. The slide part that disingages the lock is frozen and will not slide to release the gears.
And advice?
PostPosted: Sun Aug 20, 2017 1:07 pm
I guess you allready tried a fair amount of WD40 or some other lube ??
On my brand new TI I already noticed some corrosion on the grub screw for the roller bar for ghe Vangage CT seat.
There might be other components that arent marine grade stainless steel or corrosion of the aluminium parts that siezes up?
I am also intrested to hear if others had the same problem as Coyote... and how to prevent this.
All the best!!
/Gustav
Sailing my TI and fishing.... thats bliss!!
PostPosted: Sun Aug 20, 2017 1:42 pm
Ya wd40ed as much as possible, not sure I want to remove it and pull it apart
PostPosted: Sun Aug 20, 2017 2:35 pm
Coyote
Both mine stuck on my 2016 TI. A good soaking in WD40 and a little gentle persuasion released both mine.
Keep trying to release it rather than dismantle. I think it will ease up snd release.
Sent from my SM-N9005 using Tapatalk
2016 Tandem Island (Red)
PostPosted: Sun Aug 20, 2017 10:59 pm
Coyote,
I replied on your other thread that I had the same problem on my TI caused by a broken spring and Hobie are replacing the entire rod as a warranty issue.
Cheers
John
PostPosted: Mon Aug 21, 2017 4:08 am
I guess it might be worth the effort to rinse well with freshwater after every ride and be very generous with WD40 and use the mechanism often. I mostly leave mine in the highest position and seldom lower it.
Regular adjustment might prevent it from siezing up.
PostPosted: Fri Aug 25, 2017 5:36 pm
Talked to Hobie, there solution is to wd40 the slide and if that does not work cut it in half with a hacksaw and buy new ones. You think they could do better than that, what a bunch off crap.
PostPosted: Fri Aug 25, 2017 9:42 pm
Coyote, what year is your TI? Did you buy it new? Have you had it long? I'm trying to get some understanding of Hobie's response which just doesn't seem to be the norm and was certainly nothing like the response I got from my dealer with a similar problem.
Cheers,
John
