It is currently Sat Aug 08, 2026 12:20 am
PostPosted: Sun Nov 05, 2017 5:57 pm
On my 2015 TI, the port ama rides with its bow about 2" higher than the startboard. On starboard tack, the stern of the port ama goes a bit deeper than when on port tack and is not parallel to the WL like the starboard ama. I can't tell if it makes any difference at all when sailing, but the OCD in me wants them both to be the same. Ideas on how to fix?
PostPosted: Mon Nov 06, 2017 9:49 pm
My 2017 TI has similar characteristics, though my port ama rides level and the starboard one rides a little bow down/stern up. This is most obvious when sitting in still water. I've been unable to determine the cause and can't detect any detrimental effects on performance - just noticeable that's all. Perhaps subtle and unique features of the roto-moulding process...
Cheers...
Mark
PostPosted: Mon Jul 09, 2018 6:58 am
I finally figured this out. The reason is that my amas are not at all identical. One has a bit more curve and the other is flatter with less rocker. I wonder which one is right?
