It is currently Sun Aug 09, 2026 11:42 am
 Post subject: Mast rotator base
PostPosted: Wed May 16, 2018 7:23 am
hello I read that there is a new taller mast rotator base for the spinnaker kit.
I found a picture that should show the old base and the new base. it it right?
https://scontent-mxp1-1.xx.fbcdn.net/v/t1.15752-9/32457089_10156352346729784_1125831084286672896_n.png?_nc_cat=0&oh=ac0cceb414f2b97f8968cabd50472e32&oe=5B98112C
But if i look at the videos or I read the installation instructions of the spinnaker kit I cannot see this part.
I can see that the "mast tip rotator" is attached directly to the mast without any other part (base).
where am I wrong? how is this base used? how is the little hole on top of the base used, is there a screw to fix it to the mast?
 Post subject: Re: Mast rotator base
PostPosted: Wed May 16, 2018 2:57 pm
See this thread... it has images of the base and the topper. We made the base taller to help the topper clear the battens when furling the sail.
https://www.hobie.com/forums/viewtopic.php?f=71&t=62683&start=30
PostPosted: Thu May 17, 2018 12:34 am
Thanx Matt, but what I didnt understand is where and how the base is mounted. This is not shown in the videos I have seens and also in the instructions.
it is bolted to the mast top?
ps. in this recently posted pic i finally see where is the base mounted. it's inserted inside the mast tip rotator. how it is fixed to the mast probably just "plugged" without any bolt
https://asthmastory.com/images/greg1.jpg
PostPosted: Thu May 17, 2018 12:59 pm
Cprrect. It is a friction fit, with all forces on it being from below, there is no need for any other fixing
PostPosted: Thu May 17, 2018 3:05 pm
The base has a screw that attaches it to the topper.
