It is currently Mon Aug 03, 2026 1:57 am
PostPosted: Wed May 08, 2019 2:52 am
I have just received my new Tandem Island and I noticed a slight deformation on one side of the kayack when I unpacked it.
Basically there is a "flat" on the right side just between the rear aka bar and the centerboard (where the hobie logo is). My dealer tells me that it is ok and should come back by itself.
Is it somehting known on this kind of boat ?
PostPosted: Wed May 08, 2019 8:27 am
This is freight / storage damage and will pop back out. Polyethylene has molded memory and typically can be returned to the original shape.
Here is an example:
mmiller wrote:
Easy Dent Removal
Kayaks can be dented by various means, no need to worry, they are simple to remove. Improper storage, cart use, freight/transport, too much pressure on tie-down straps all can cause a dent in a kayak. We have the solution. Watch Jacques Bernier in the video linked below. Jacques explains the simple procedure that, as you will see, can remove even a nasty dent in the side rail of a kayak.
Dent Removal Video: http://www.youtube.com/watch?v=OpuIJzMotDg
Success Story:
