It is currently Fri Aug 14, 2026 11:44 pm
PostPosted: Sat Jul 06, 2019 6:33 am
Does anyone know if if there is a way to mount the new Torqeedo 403 AC while retaining rudder control while under sail without the motor running? I was researching it last night and couldn't find a solution online using their new mount.
Thank you
PostPosted: Wed Jan 22, 2020 5:26 pm
Hi ntbucholtz,
Did you discover a rudder attachment for the shaft of the Torqeedo 403?
Cheers
PostPosted: Thu Jan 23, 2020 9:03 am
On the standard 403, I accomplished this by mounting it just aft of the rudder and offset to one side. This way, the rudder is free to move in all directions including up and down.
Since the 403AC does not include a rod to extend it outward as does the 403 and 403C, you'll have to devise your own. Perhaps a flat metal plate to get it to extend beyond the rudder. It should be doable with a little fabrication.
BTW, if you're considering the 403AC, you should also look at the new 1103AC which has 3HP rather than 1HP and doesn't cost that much more.
