It is currently Fri Aug 14, 2026 5:53 pm
 Post subject: SeaDek on TI?
PostPosted: Mon Feb 10, 2020 4:44 pm
Have any of you installed SeaDek on your TIs? Pros/cons?
Any advice and/or pictures would be appreciated.
2015 Hobie Tandem Island
Ivory Dune
Trampolines, Spinnaker Kit, Lowrance Hook4, Vantage Seat Accessory Bags, GoPro Hero3+, RTIC SoftPak 30, WaterPORT Day Tank
 Post subject: Re: SeaDek on TI?
PostPosted: Mon Feb 10, 2020 8:37 pm
I installed HydroTurf on the deck of my TI. It was an excellent improvement.
PostPosted: Mon Feb 10, 2020 10:07 pm
[quote="pro10is"]I installed HydroTurf on the deck of my TI. It was an excellent improvement.
Looks like a neat job! How did you do the template? Masking tape trick?
PostPosted: Tue Feb 11, 2020 8:41 am
For a template, I simply used clear plastic sheeting, the kind used as a vapor barrier for insulation. I carefully laid it out over the deck and traced the pattern onto the sheeting using a sharpie. I then cut the sheeting on these lines and laid it over the HydroTurf as a template.
This worked great and allowed for a very accurate installation. There may also be other ways to do this, but this worked well for me.
PostPosted: Tue Feb 11, 2020 3:30 pm
Nice, looks very neat!
My plan B was to use that technique, I ended up creating a template with masking tape and tracing it. But in hindsight the clear plastic option would have been a lot more accurate.
