It is currently Tue Sep 08, 2026 12:48 pm
PostPosted: Sun Mar 22, 2020 12:34 pm
Good day all. I just bought the Hobie wind vane that goes on top of the mast. The only issue I have with it is trying to place it with the arm out in front of the mast. Each time I try I put it in the wrong position. Anyone have a tip on how to place it correctly?
PostPosted: Tue Mar 31, 2020 10:38 pm
Put the wire part poking out, the opposite direction/side to the stitching in your sail :)
PostPosted: Thu Jul 22, 2021 6:37 am
Debated on starting a new topic, but figured a search on wind vane is better kept together. Below are pics of a method someone in my family employed which is pretty simple. The only catch is that you have to singe/melt with a small awl a hole in the nylon captive strap that loops over the top of the mast cap. Then drill a small pilot hole about 1/25" into the mast cap and attach a 1/2" SCH 40 PVC cap. Then using a "Little Hawk" wind vane and wine cork (check you cork fit in the 1/2" PVC before committing, some are too loose). That's it, pretty simple if you ask me. I'm adding one the the 2013 AI in the back ground tomorrow.
Thank you,
Roy Niswanger
