It is currently Fri Aug 14, 2026 4:48 pm
PostPosted: Sat Aug 22, 2020 1:11 pm
Knowing the interest in adding power options (outboards / electric drives) to our islands....came across this home built option with a fair bit of power! 46 hour run time!
https://youtu.be/WqLBwzXMl6s
Jim
Hobie TI 2022 - Offshore rig - Outboard - having fun!
Hobie TI 2021 - Offshore rig - Outboard - sold
Hobie TI 2016 - Offshore rig - Outboard - sold
Hobie Kona 2014
Hobie AI 2015 - sold
Hobie Rev 13 2014 - sold
Hobie Outback - 2008 - sold
PostPosted: Sat Aug 22, 2020 6:47 pm
A bit more with on the water tests.
Range test will be next.
Interesting to compare this to other electric options for the Islands.
Jim
Hobie Kona 2014
PostPosted: Sun Aug 23, 2020 4:53 am
Wow. This guy is best described as a mad scientist. While what he accomplished is quite impressive, this is so not ready for prime time, and virtually no one is going to be able to replicate his work to make this in any way practical unless you too have your own milling machine.
That battery setup alone is a recipe for disaster. I wouldn't be at all surprised if it burst into flames spontaneously. You cannot simply ignore the safety requirements of powerful lithium-ion batteries like that. Even with all the incredible engineering and safety considerations at Boeing on the 787 Dreamliner, their lithium-ion batteries dangerously overheated. You just can't stuff a bank of lithium-ion batteries into a cheap plastic case like that. If just one cell fails it's going to be a serious meltdown.
Unless you're a Doc Brown, this has no practical application for the TI or AI.
