It is currently Tue Sep 08, 2026 1:16 pm
 Post subject: SeaDek for the TI
PostPosted: Mon Oct 05, 2020 6:49 am
Hi. I spoke to my local Hobie dealer yesterday and he told me that SeaDek does not offer a kit for the Tandem Island, only the Adventure. Does anyone know how I should go about getting a kit made for a TI? Is this something I'd have to make myself? Are there other reputable manufacturers out there like Marine Mat that offer a TI kit? Thanks!
2015 Hobie Tandem Island
Ivory Dune
Trampolines, Spinnaker Kit, Lowrance Hook4, Vantage Seat Accessory Bags, GoPro Hero3+, RTIC SoftPak 30, WaterPORT Day Tank
 Post subject: Re: SeaDek for the TI
PostPosted: Mon Oct 05, 2020 7:48 am
There are no such kits for the TI as far as I know but you don't need one. It's easy to cut one out yourself using bulk sheets available from Hydro-Turf and others.
Using clear plastic sheathing, simply trace out the pattern directly from the TI's deck using a sharpie. Then cut the sheathing and use it as a template to cut the bulk deck material. The Hydro-Turf I used had an adhesive backing. Simply clean the TI's deck using denatured alcohol and apply the material. It will last for many years.
PostPosted: Tue Oct 06, 2020 11:32 am
I like the looks of that. I think that would help cut down on noise and add to comfort. Not to mention it looks great!
PostPosted: Tue Oct 06, 2020 7:41 pm
Yes but it also adds weight - a considerable amount depending on how much surface you intend to cover.
PostPosted: Wed Oct 07, 2020 5:14 am
??? The stuff is very light foam and very little is needed for the TI. A 37"x58" bulk sheet weighs only one pound.
PostPosted: Wed Oct 07, 2020 5:34 am
Thank you. I was going to ask if needed more than 1 sheet.
PostPosted: Wed Oct 07, 2020 7:15 am
It all depends upon which sections you wish to do. It's very easy to measure. Also, the sheets come in various sizes.
PostPosted: Thu Oct 08, 2020 7:18 am
SeaDek has the dimensions posted for the AI kit. I am going to compare the dimensions of the cockpit area, but I can’t imagine they are very different- the TI just has an extra one. If it’s a close match, I am going to order the AI kit and then contact SeaDek to see if they will sell me another but without the pieces for the rear cargo area. I’ll post my findings.
Ivory Dune
