It is currently Tue Sep 08, 2026 12:24 pm
PostPosted: Sun Aug 01, 2021 12:28 pm
Hi everyone,
New TI owner (and I love it), I would like to know if there is a way to remove the water that fills the mast receiver without removing akas, amas, and turning the main hull ?
Thank you.
PostPosted: Sun Aug 01, 2021 6:18 pm
As luck would have it, my manual bilge pump fits in the receiver keeping the ball-bearings in place when traveling and allows me to remove most of the little water that gets in.
PostPosted: Mon Aug 02, 2021 5:44 am
I stuff a microfiber cloth in, takes a few cycles depending on the amount of water.
PostPosted: Mon Aug 02, 2021 8:00 am
Turkey Baster, dirty towel, long screwdriver. The sequence will come to you.
'09 Adventure Island (SOLD)
2017 Tandem Island
PostPosted: Mon Aug 02, 2021 3:32 pm
Thank you folks.... microfiber will be cheaper than a bilge pump !!!
PostPosted: Wed Aug 04, 2021 5:18 pm
1. Bilge pump to get most out
2. Sponge taped to stick to get the rest
3. Foam noodle with waterproof tape at the top to keep new water from getting in while stored
Hope that helps
PostPosted: Sat Aug 07, 2021 10:10 am
I use a wet/dry shop vac to remove the water and any other debris in the mast receiver.
