It is currently Tue Sep 08, 2026 12:25 pm
PostPosted: Thu Mar 12, 2026 12:21 pm
I am trying to rig a Mirage Tandem Island and need correct rudder control line as well as other small parts. Any suggestions? Thanks
PostPosted: Mon Jun 22, 2026 4:14 pm
Hobie used 2mm Spectra cord which is a little more difficult to source. You can probably find 2mm Dyneema much easier (Amazon). The two are basically identical, with a small change in the manufactures process. YouTube search for “Replacing Hobie Rudder Control Lines”. There are several videos on the topic. Use a phone to take pictures inside the boat (if you can’t get your head inside to see. It’s not a difficult process, easily done with basic skills. Good luck !
