It is currently Sun May 05, 2024 8:28 pm
PostPosted: Sat Aug 26, 2023 12:09 pm
I have a 2009 AI that developed a crack under the click-n-go. I’m going to try to weld it then cover with G-flex. If that doesn’t work an out of state friend has a slightly newer AI hull ( with the orca fin rudder & the aka’s that are tube like and slide into each other instead of the pins mine has). If I unbolt my Xbar, is the spacing the same to put my bars on his hull? Thank you.
PostPosted: Thu Aug 31, 2023 6:17 pm
Let me try wording it differently. Can the sailing parts of a 2009 AI be bolted on to a later year AI hull or are the bolts spaced differently? Thank you.
