It is currently Tue Sep 08, 2026 12:10 pm
PostPosted: Sun Apr 14, 2024 11:38 am
Hello - I recently replaced the rudder lines on my 16' Mirage adventure. I used the universal kit for the Mirage but the guide tubes are much shorter and the spectra line is making contact with the inside of the hull. Should I be concerned that will cause premature wear from rubbing over time?
Should I have gotten the kit for the AI/TI instead since this is a 16' boat? It looks like that kit has longer guide tubes.
Appreciate your insight.
Thanks,
Kevin
PostPosted: Mon Apr 15, 2024 8:49 am
Yes.
80019012 LINE KIT AI / TI CONTROL REPLACEMENT
PostPosted: Mon Apr 15, 2024 12:02 pm
Thanks Matt - I would say Hobie should add that exception for 16' boats to the description of the "HOBIE LINE KIT MIRAGE RUDDER UNIVERSAL" as I spent a hundred bucks on it and now I'll need to get the AI/TI kit which does not have any mention in the description that it works on certain older Mirage models.
PostPosted: Sun May 05, 2024 4:37 am
Cannot find this part anywhere. Out of stock from all usual sellers online.
Does anyone have one they would sell or can recommend where I can find one?
PostPosted: Sat May 11, 2024 3:10 am
In stock here in Canada: https://shop.foghmarine.com/line-kit-mi ... al-ti.html
PostPosted: Sat May 11, 2024 6:21 am
Thank you Paul - not clear if they ship to the US, I sent them an email though. Really appreciate your help!
PostPosted: Sat Jun 08, 2024 1:58 pm
mmiller wrote:
Yes.
Matt I'm perplexed -- I found what might be the last AI/TI Line Control kit left in existance (Shipped from Canada to US no less!) and the guide control tubes are the same length as the standard kit. The only difference is the spectra line might be a bit thicker.
I'm now out $200 on this endeavour and still no closer to having the correct length guide tubes to prevent the spectra from rubbing inside the hull. Any recommendations?
Here's an image of the kit I bought - I opened the kit, it was sealed like from the factory, and compared the guide tube length to the ones I installed from the standard kit.
https://drive.google.com/file/d/1ge7srS ... sp=sharing
Thanks,
Kevin
PostPosted: Tue Oct 01, 2024 7:52 pm
That's a bummer about the rubbing issue. I had the same problem with my old 16' Mirage. I ended up replacing the kit with one for the AI/TI and it was a perfect fit. The longer guide tubes made a huge difference in preventing chafe.
I'd definitely recommend checking out the AI/TI kit. It's a little more expensive, but it's worth it in the long run to avoid having to replace the lines again.
PostPosted: Wed Oct 02, 2024 3:29 am
@Ackley - yes I bought what was supposed to be a kit for the AI/TI and the tubes are still too short -- either Hobie made a production error or changed the product without realizing it would no longer function perfectly.
I do worry about the lines chafing - I had this kayak over a half mile out into the ocean in rough seas lately on a trip which was over 20 miles total, losing rudder control would be a mess - would have to steer with the paddle the whole way home.
Between that and chasing down a leak I'm ready to cut this kayak up and put it at the curb, but you can't get a 16 footer anymore, these are becoming scarce!
PostPosted: Tue Jun 24, 2025 5:13 am
I picked up the kit from my local dealer part # 80019012 for 2020 TI.
The tubes go past the hatch. Do you cut them to make them fit? I can't believe instructions or video to install this kit that hobie sells is nowhere to be found.
