It is currently Thu Aug 06, 2026 6:32 pm
PostPosted: Thu Jul 16, 2026 8:52 am
I'm a New sailor having a blast with my Tandem Island.
The rudder steering and up/down controls all seem to be getting impossibly hard to operate. I feel like I'm going to rip something apart trying to get the rudder down. Any tips?
PostPosted: Thu Jul 16, 2026 5:05 pm
Tore into it a little today and found that the string that works the pulley system to operate the rudder (tandem up and down levers) are spinning the pulley and twisting around each other. I untied the knots, removed the twist, and all worked well. Now, I am noticing after just a few uses, the strings are twisting up again. What's up with this?
This is a used boat, and I replaced several of the worn strings, so it's possible I've strung something incorrectly.
Is there a special technique or knot that is used that prevents the strings from "spinning"?
Is there a drawing somewhere of how the strings should be routed?
I assume the pulleys have to hang and move freely (and can't be fixed) as movement is required to pull the rudder controller strings.
PostPosted: Mon Jul 20, 2026 2:39 am
Your rudder lines might be twisted. Look through rear hatch, use phone or camera. If lines are twisted use search tool to find ways to fix line twist. Good luck.
