It is currently Sat Aug 22, 2026 10:48 pm
PostPosted: Wed Sep 26, 2007 8:13 pm
I have bought 2 days ago the Adventure 08 model that it is in transit from Hobie.I need to add only the outriger that is on the Island model. What is the part number needed and do I have to do any drilling on the haul.
PostPosted: Thu Sep 27, 2007 7:58 am
That's going to be some work. Yes, drilling is required. No, I don't know where or what size bits. I believe the Island Ama Kit ($899 USD)will have everything you need, but have not seen one yet.
99403001 - Papaya
99404001 - Hibiscus
99405001 - Dune
Brian C
PostPosted: Thu Sep 27, 2007 12:45 pm
If you're installing just the outriggers and not the sail, I would thing it would be just 10 bolts, with no drilling, if the brass inserts are already molded in the hull. Four each for both Aka supports (Xbar), then the 2 Ball Braces.
Kayaking Bob
PostPosted: Thu Sep 27, 2007 1:12 pm
I think Bob is correct. We just unwrapped an '08 Adventure, and it looked like all the screws were already on the boat for attaching the XBar assemblies.
What I'm not sure about is if the Ball for the brace is alreay mounted, and the yak just drove off.
Brian C
