It is currently Mon Aug 10, 2026 11:14 am
 Post subject: Ladder Rack Update
PostPosted: Fri Jun 14, 2019 11:19 am
Here is the (almost) finished project.
https://i.postimg.cc/3RGVPTdz/next-to-trailer.jpg
https://i.postimg.cc/zG0rj8gj/20190614-134233.jpg
https://postimg.cc/JGdSW73C
Had to extend dolly height to keep rudder off the ground when unloading
https://postimg.cc/3dwz60vZ
Pivot close up
https://postimg.cc/4nPrBQmd
Sorry about the link for pics, couldn't get them included any other way.
 Post subject: Re: Ladder Rack Update
PostPosted: Tue Jun 25, 2019 11:17 am
Nice job putting that together. Looks like a good setup.
PostPosted: Thu Jun 27, 2019 9:27 am
I like it!! If I ever car top again for some trip, I think I will dump my 2x4 wood heavy and still not stiff enough monster cradle and go with the ladder idea.
PostPosted: Wed Dec 02, 2020 8:39 pm
Great idea
Mickey
2016 AI Hibiscus
PostPosted: Wed Dec 02, 2020 10:09 pm
Very nice!
I embedded your image links below for easier viewing.
Peter
PostPosted: Thu Dec 03, 2020 7:18 am
Thanks, should have imbedded them. The setup works great, I can load and unload alone. The dolly was a challenge, had to make it taller to avoid scraping the boat. So far it has worked great, took the boat from PA to FL and had 0 issues. The design might get refined though, the ladder and PVC are rather heavy and not sure it needs to be. May try lightening it or put more reinforcement on the ladder rack mounts.
PostPosted: Thu Dec 03, 2020 8:50 am
We have an Oasis tandem we usually trailer but there are times I’d rather throw it on top of our minivan, especially for one-way river trips (two vehicles needed) and when our destination has no trailer parking. The Oasis is a bit more manageable being 2’ shorter than an Island and 4’ shorter than the Tandem Island. Because there is stuff inside and on the hull, including a rudder-mounted Torqeedo (Evolve) and controls, I would need to transport upright like we do on our trailer. I have been looking at how to replicate my trailer PVC bunks for easy roof-rack attachment so find your post interesting.
Peter
PostPosted: Tue Dec 15, 2020 11:39 am
Quattroguy, this is the best idea that I've seen for transport on a roof rack system. Can you tell us the diameter of the PVC? That looks like a 14' ladder - Please confirm. They say imitation is the sincerest form of flattery . . . I'm going this route!! Well done!! :D
PostPosted: Tue Jan 12, 2021 7:16 am
Thanks, shared this because it works so well and transporting these has many options. I insisted the boat go camping with us, wife wanted a travel trailer instead of a class A, so this was the logical answer. The tilt to unload is awesome.
Tube is 2-3 inches, not sure of ladder length but your guess is probably close. I overdid the design, have had the opinion for years that small boats get flexed more in transport than use. Downside is this is a heavy load up high, you can really feel it. The ladder rack goes into the stake pockets, with "feet" on the rack verticals. I will be making some plates to carry some of the load on the bed rails.
Hope this helps, and hope it works out as well for you. Be prepared for some curious observers when you use it, we usually have people offering to help but with this it is a one geezer operation!
PostPosted: Thu Jan 21, 2021 8:24 am
Can you post photos of loading/unloading? I'm not sure how pivot works. Thanks.
PostPosted: Fri Jan 22, 2021 6:30 am
Pivot is on the crossbar right behind the cab. Boat is balanced so it tilts to horizontal when the drain scuppers are in the PVC cutouts. I used a pulley on the front rung of the ladder and hook it to the boat thru the drive slot on to the front ama crossbar.
This spring when the boat is out of storage I will make a utube video of the construction details and load/unload process.
PostPosted: Fri Jan 22, 2021 9:32 am
Thanks.
PostPosted: Tue Jun 03, 2025 6:18 pm
I replicated your ladder idea so I could single hand an oasis tandem - worked fantastic! I added a pair of dolly wheels to the front of the ladder for easy storage at home, and stopped the dreaded ladder whistle on the freeway by hitting all the rung interiors with some spray insulation foam.
