It is currently Sun Jun 21, 2026 5:49 am
PostPosted: Wed Jun 30, 2010 5:56 am
A boat trailer makes a great platform for carrying kayaks. By adding a rack or two it’s surprising what you can fit. Here is a TI, 2xAI’s, and an Oasis which are easily under the 400kg capacity of this trailer.
I found it easier to transport the TI on top and keep the AI's assembled. The TI is easier to manage in separate bits and the lock in aka make it easy to assemble at the boat ramp.
So the trailer remains balanced it’s better to extend the rear of the trailer if possible. That way the overhang will be less. This is less overhang than 1.2m and so doesn’t require a flag here in NSW.
Another solution is to modify a box trailer and lengthen the drawbar. On this little Aunger trailer, which I use to transport the TI alone, I have added a 4m drawbar. Some extra angle braces strengthen the frame and eliminate the snakiness such a long drawbar can have. There is over 1.2m overhang here so a flag is necessary, but the box trailer gives you somewhere handy to store the drives and accessories. I prefer to transport the TI hull down and it’s not too difficult to slide it up and then flip it over.
PostPosted: Wed Jun 30, 2010 6:04 am
That's hull down? I think you were still tired from lifting that TI hull when you wrote that! :shock:
Nice setups! :)
PostPosted: Wed Jun 30, 2010 6:09 am
Everythings upside down downunder! :wink:
Oops, thanks for that Bob, I meant hull up on the box trailer! :oops:
PostPosted: Wed Jun 30, 2010 6:14 am
I like that first trailer.
I'd rather be sailing,
Mark.
PostPosted: Wed Jun 30, 2010 7:43 am
Here is what I wound up with.
“Remember life is short- eat dessert first.”
The world is 70% water – So that means we should spend 70% more time sailing than mowing lawns!
Larry
PostPosted: Fri Jul 02, 2010 7:09 am
It all makes me happy that I have an AI (actually, 2 AIs).
