It is currently Thu Apr 25, 2024 11:15 pm
PostPosted: Sat Jul 31, 2010 8:08 pm
I have a new Hobie Double Trailer and after its first 100 miles or so I noticed the inside of one wheel has sprays of grease around the rim. It looks like grease is spewing out of the bearing on the inside and the centrifugal force of the wheel and bearing turning is slinging the grease around the inside of the wheel. Has anyone else experienced this? I am concerned about losing too much grease and having the bearing overheat and fail.
Mark
2010 Tandem Island
2010 Adventure
Hobie Cat 14T
Home built sailboat (in progress)
Edmond, OK
PostPosted: Sat Jul 31, 2010 8:32 pm
That's normal. I added Bearing Buddies and the Bra so it wouldn't happen on mine.
PostPosted: Sat Jul 31, 2010 8:39 pm
I am familliar with bearing buddies, but not the Bra. The grease is only coming out on the inside of the bearing, not the outside where bearing buddies mount.
Mark
2010 Tandem Island
2010 Adventure
Hobie Cat 14T
Edmond, OK
PostPosted: Sat Jul 31, 2010 8:51 pm
I haven't seen that with mine, but maybe the Bearing Buddies make it different.
PostPosted: Sat Jul 31, 2010 9:26 pm
yakaboutit, If you have grease on the inside of the wheel your rubber seal is damaged or blown out...forcing too much grease in the hub could do this or it could be a bad seal...
CaptRon
"Anything's gonna happen,
it's gonna happen out there"
PostPosted: Sun Aug 01, 2010 11:13 am
Thanks for the advice!
It sounds like I should take the bearing cover off to see how much grease is in there. If there is substantial grease I will clean the wheel and watch for additional grease spatters. If the grease keeps coming out, it's probably a bad seal and should be covered under warranty considering this is a new trailer.
Mark
2010 Tandem Island
2010 Adventure
Hobie Cat 14T
Edmond, OK
