It is currently Sun May 19, 2024 11:12 pm
 Post subject: TI Storage over winter
PostPosted: Fri Sep 20, 2013 12:34 pm
Is it OK to store a TI on the trailer over winter? Should I put it upside down. Winter temps here are very cold, below freezing every night. The TI will be in a shelter out of the snow. thanks
PostPosted: Sat Jan 24, 2015 10:39 am
I am sorry that you have not had a response. I am also interested in finding the best way to winter store. Dom
PostPosted: Sat Jan 24, 2015 9:47 pm
I've been told that you can safely store both the AI and TI on the trailer if you are using the Hobie cradles and they are spaced correctly. If it's going to be stored outside in a wintery environment and not sheltered then it's probably best to turn it upsidedown to keep snow from getting inside. I plan on storing mine in the trailer with cradles in the garage.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Mon Nov 02, 2015 9:43 am
Ok to simply just put it upside down and store directly on cement basement or garage floor?
Thanks.
PostPosted: Mon Nov 02, 2015 6:09 pm
Should be fine. As long as it's upside down and resting on the gunnels.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Mon Nov 09, 2015 10:06 am
Ok. Thanks.
