It is currently Wed Aug 05, 2026 6:00 am
PostPosted: Wed Mar 15, 2017 4:31 pm
I live in Fort Eustis, VA, on post housing. In my situation, we do not have a big backyard nor do I have a garage to store my hobie. I currently wall mount my hobie. is this ok?
PostPosted: Wed Mar 15, 2017 4:55 pm
That wouldn't be great long term no. The issue is all the weight being point loaded on those 2 spots where the strap wraps the sides of the hulls - it will distort. The manual is pretty clear what Hobie recommends - and what we warn against. link: https://docs.google.com/viewer?url=https%3A%2F%2Fstatic.hobiecat.com%2Fdigital_assets%2F897005-tandem-island-manual-150701.pdf
Jacques Bernier
http://www.hobie.com/
PostPosted: Wed Mar 15, 2017 5:48 pm
If I hung this upside down, then it's good to go?
Sent from my XT1585 using Tapatalk
PostPosted: Wed Mar 15, 2017 11:57 pm
profiled stiff foam (similar to bouyancy foam supplied) between hull and straps to spread load and even a couple of extra straps to spread the load. Alternate which side you store it on
PostPosted: Thu Mar 16, 2017 9:56 am
Yes - it would be 100 times better - but you'd still want to spread that load, the straps can 'squeeze' down onto the boat - but if the boat were resting on a couple beams and then hung or on a rack it would be best.
Jacques Bernier
PostPosted: Fri Mar 17, 2017 12:04 am
You could leave it there if you used 4 kayak wall racks, padded, mounted to studs. Straps for security.
Your wallboard's gonna be trashed by the time you rotate out though.
Nice wall ornament. :mrgreen: Great conversation piece.
The Wind Is Your Friend...
PostPosted: Fri Mar 17, 2017 3:31 pm
Can i store it on my trailer? As you can see, that is the size of my backyard.
Sent from my SM-T350 using Tapatalk
PostPosted: Fri Mar 17, 2017 9:13 pm
Yep. You can store it on the trailer. It won't be any wider than that but it will be longer. I would recommend getting a cover if storing outside. Additionally, I would look at swapping out the cradles for pvc bunks to keep the distortions to a minimum. Ft. Eustis doesn't have an RV/boat storage lot you could use?
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Sat Mar 18, 2017 4:54 am
They do but it's outside in a locked fence area. I don't want my stuff getting stolen.
PostPosted: Sat Mar 18, 2017 7:35 pm
Locked fence area should be pretty secure. Not to mention you're on post. There are ways to secure the TI to the trailer and secure the trailer so no one can drive off with it. Hmmm...it might still fit in your "back yard" on the trailer.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
