It is currently Mon Aug 10, 2026 5:10 am
 Post subject: Daggerboard Separating
PostPosted: Sat Aug 06, 2011 3:12 pm
My daggerboard is separating from the tip down about 4 or 5 inches. What is the best way to fix this? Is there some type of epoxy I should use? Any help would be appreciated.
Thx.
PostPosted: Mon Aug 08, 2011 1:39 pm
G-Flex and fiberglass, I would guess.
http://www.westsystem.com/ss/g-flex-epoxy/
There are some videos at the West System site that may give you guidance.
I have the older fglass dagger. The newer ones are plastic, I believe, and may respond to heat sealing.
The Wind Is Your Friend...
PostPosted: Mon Aug 08, 2011 5:39 pm
Thanks, I'll check out West Marine.
PostPosted: Mon Mar 26, 2012 7:28 pm
Any luck with the dagger repair?
I, um,.. er,... hem, need to do it too. :oops:
