It is currently Fri Aug 21, 2026 8:37 am
PostPosted: Wed Sep 09, 2015 11:45 pm
Has anyone else had problem with new 2015 AI2 rudder uphaul lines?Mine is always jumping off the front pulley and getting jammed next to the centre roller.It is not hard to put back once I get back to shore,but not able to do it while in deep water,as you have to open front hatch to access the pulley wheel.If it keeps happening, the line will eventually chafe and then break.Anyone have any ideas?
PostPosted: Thu Sep 10, 2015 12:24 pm
Check for line twist. Pull all the way out of the hull, then grab near the hull opening and see if the line with un-twist.
Check inside using a small camera to see if there is a routing issue.
