It is currently Sun Aug 23, 2026 12:19 am
 Post subject: quality control
PostPosted: Wed Aug 16, 2017 12:08 am
I recently purchased a revolution 13, and have noticed that one of the two bottom holes under hull (hole closest to mirage drive) has brass bolt exposed with jagged plastic around same. Is this normal or just a cosmetic issue? I figured for $2500 this would not be overlooked. I have a rev 11 on order and am reconsidering my purchase. The hole forward which connects to mast is flush with the hull.
 Post subject: Re: quality control
PostPosted: Wed Aug 16, 2017 7:51 am
One is for the fitting below the mast base. The second reinforces the forward ledge of the drive well. Both typically would have small caps (panel rivets) covering the threads. This is a molded-in fitting and some flashing (plastic bits) around them is normal. They can sometimes protrude a bit. This is normal for a roto-molded boat.
The threads are how the part is held into the mold. The threads do not extend through the brass and the brass parts are completely encased in plastic inside the boat.
PostPosted: Wed Aug 16, 2017 12:48 pm
thanks for reply, the brass bolt head itself is visible and protruding outside hull. it appears extra plastic was added as well. assuming this is not normal as other hole is flush and encased within hull.
PostPosted: Wed Aug 16, 2017 1:06 pm
Yes, they can sometimes protrude a bit as a bump on the bottom.
How about a photo?
PostPosted: Wed Aug 16, 2017 5:19 pm
For whatever reason I cannot attach photos to this forum. I will send you email from [email protected] with photos in reference. Thanks.
PostPosted: Thu Aug 17, 2017 8:54 am
For future reference:
mmiller wrote:
Posting an image... Images must be hosted at a location on the internet. (Suggested site: imgur.com or flickr.com)
Check the image below. Right click on the image to see the copy image address popup option:
Image URL ends in .jpg or .png or similar.
Navigate to your image page. Right click the image and copy the "propeties". This must be an image address (url) rather than a url to a page. Click the above image to test and look at properties and address (url).
Rather than a link to the page it was on. The address should end in something like .jpg or .gif
Use the buttons above the post text area to find the proper code.
Use [img]then%20the%20image%20url%20and%20click[/img] again.
Be sure to have the option " Disable BBCode " unclicked!
and you are done.
PostPosted: Thu Aug 17, 2017 8:57 am
For others reference:
That appears about normal. Bit of excess flashing that could be trimmed, but the white "panel rivet" normally protrudes like that. The brass looks flush as it should be. They are all a little different. They are bolted in the mold and have to be released at a specific time period as it cools and starts shrinking. The hulls actually shrink 4% from the size of the mold, so there is some movement happening inside the mold before it cools enough to pull the hull out of the mold.
