It is currently Wed Aug 26, 2026 4:50 am
PostPosted: Sun Aug 09, 2020 6:47 am
2016 AI: I moved my mainsheet block inboard to facilitate the trampoline and now the main sheet rubs across the hull. I've temporarily protected the hull with some tape but would like to add a chafe plate like the one on the stern. I've searched the hobie site and google. This part is mentioned in a TI discussion from 2007. Does it exist? A part number would be great. Thanks.
PostPosted: Mon Aug 10, 2020 11:06 am
88991097 CHAFE PLATE, TI
8030671 SCREW 8-32 X 5/8 PHMS-P (2)
Main sheet Chafe Plate
This product enhancement is to be installed on the rear deck of each Tandem Island. Most boats will have two dimples to locate the part properly on the right side of the rear deck. The correct location is where the main sheet contacts the hull between the aft block and first set of bullet blocks that direct the lines forward. If no dimples are present, simply pull the main sheet taut across this area. position the plate in a fore / aft orientation to prevent the main sheet from contacting the deck.
