It is currently Sat Aug 08, 2026 5:36 pm
 Post subject: Plastic welding rods
PostPosted: Wed Feb 01, 2023 7:39 pm
Hi all. I just purchased a 2005 (06 Model) Mirage Outback Fisherman Hank Parker Edition.
It has quite a few scratches & cracks so I have a bit of welding to do.
I see that the KC Welder Pro kit is the one of choice but where can I but more rods, preferably in Australia not essential?
It's the mottled green colour.
Thanks in advance.
 Post subject: Re: Plastic welding rods
PostPosted: Thu Feb 02, 2023 8:12 am
You can usually request welding rods at a Hobie dealer and get them for free. You can also get larger scraps cut from decommissioned kayaks. If you don't have a dealer nearby, reach out to https://slhobie.com.au/.
Peter
PostPosted: Thu Feb 02, 2023 3:42 pm
Thanks mate, I'll try that.
PostPosted: Fri Feb 03, 2023 8:12 am
If you just have scratches and not deep gouges that can lead to a hull puncture, I would skip using the KC Welder Pro. It certainly does not improve things cosmetically and should only be used when absolutely necessary to repair or prevent serious hull defects.
If your hull is cracked in multiple areas to the point where water is coming in, I would argue that the hull has exceeded its service life and needs to be replaced, especially if any cracks are below the water line.
