It is currently Fri Aug 07, 2026 3:36 pm
PostPosted: Sat Feb 24, 2024 1:49 pm
My TI front seat height adjustment bar is stuck in the lowest position. How do I raise it back up? Pulling the strap and lever doesn’t release it :|
PostPosted: Sun Feb 25, 2024 5:02 am
Stand at the right hand side of your ti
Left hand on the bar
Right hand on the release ring (far end)
Pull release ring in to your direction (+_ 1/3 of an inch)
Turn bar with left hand counter clock wise
A bit of wd40 might help
Hope this is clear enough
sorry for my typos, english is not my first language ( not my second either)
Peter
PostPosted: Sun Feb 25, 2024 9:36 am
Thank you Peter
I will try that this afternoon !
PostPosted: Tue Mar 05, 2024 8:07 pm
Thank you for the clear instructions, and the WD-40 tip! I'll definitely give that a try. I appreciate the effort you put in to explain it, even though English isn't your first language. No worries about the typos, I understood perfectly.
