It is currently Fri Aug 07, 2026 4:57 am
PostPosted: Mon Sep 16, 2024 4:15 pm
I found a crack in the forward drive well on my Tandem Island.
https://imgur.com/a/PQavSYd
https://imgur.com/a/JmwTUaE
https://imgur.com/a/F2C37fG
I decided to try the Loctite 3035 rather than the welding method. Because the 3035 is a thick liquid I was able to squirt it into the crack and "mushroom" it over on the inside and outside. After curing (it took 4 days to fully harden) I was able to sand it smooth. It seems to adhere very well to the polyethylene.
I'm very happy with the way it turned out.
https://imgur.com/a/3VfBH06
https://imgur.com/a/FS8wdeh
PostPosted: Fri Sep 20, 2024 12:18 pm
Let us know how it holds up in use.
Peter
PostPosted: Mon Sep 23, 2024 9:58 am
Any idea as to what caused the crack?
Did you check the underside of the hull for any cracks below the drive well?
Jim
Hobie TI 2022 - Offshore rig - Outboard - having fun!
Hobie TI 2021 - Offshore rig - Outboard - sold
Hobie TI 2016 - Offshore rig - Outboard - sold
Hobie Kona 2014
Hobie AI 2015 - sold
Hobie Rev 13 2014 - sold
Hobie Outback - 2008 - sold
PostPosted: Wed Mar 19, 2025 11:06 am
It's been 6 months since I did the repair and I thought I would post an update. I sailed the boat in Michigan thru the summer with no leaks. In February I took the boat to Florida for two months. My first sail in Florida I had a small leak. Don't know if it was the temperature change or the 1,500 miles of vibration. I applied another coat of Loctite 3035 and let it dry for 4 days. I haven't had a leak since. We'll see what happens when I bring it back to Michigan. I'll post another update in the summer.
